wedgemate fly wheel
https://forums.aussieveedubbers.com/threads/84296/wedgemate-fly-wheel
turboboy ·
Howdy
is it possible to machine a stock ended crank to fit a wedgemate fly wheel or do you have to buy a matched pair.
If it's possible what are the dimension's of the cuts to the crank that have to be made. I know it will have to match the f/wheel but are they all different (brand wise) or the same.
Cheer's😎
dangerous ·
Most are done to match a specific crank and FW combo.
There are a few different angles, but generally it is around 3 degrees.
Most weld the FW and the crank is turned to match,
but some times the crank nitriding is very hard, so it needs wlding also.
It IS possible to match a stock crank, but you may end up having to weld.
And the crank dowel pins must be removed too.(PITA on some aftermarket cranks).
