Inside Door Handle
https://forums.aussieveedubbers.com/threads/84316/inside-door-handle
clinker42 ·
Hey Guys
The Inside door handle plastic covers, is there 2 parts to them, a cover that screws on then a cover that clips into the screwed on bit.
I have these George sent me but they dont seem right, having those holes you can see the door through the holes.
rob53 ·
Yes they come in two bits. There is an inner bit that clips in (after you screw the outer bit on the door).
ian.mezz ·
all so have you put a plastic sheet behind door trims??? with out the cover on you shouldnt see the door just the plastic sheet that stops the water getting in.🙅
and the trim on the side rear s??????
