GTMac ·
After a Hella H4 headlight set, the standard 7inch that will fit in most cars with big round headligts such as holden HQ-HZ etc. So to simplify, something that fits either Type 3 or Kombi ( no idea if same for Beetle).
https://forums.aussieveedubbers.com/threads/84343/wtd-hella-h4-7-inch-headlights
GTMac ·
GTMac wrote:After a Hella H4 headlight set, the standard 7inch that will fit in most cars with big round headligts such as holden HQ-HZ etc. So to simplify, something that fits either Type 3 or Kombi ( no idea if same for Beetle).
bus914 ·
these lights don't have any adjusting screws etc..bus914 wrote:There are two main types i think. Original semi-sealed H4 lights that use the two extra adjusting screws in the rim, and the sealed type that has a one screw rim. The semi-sealed could be pretty hard to find the other type you can get in most places.
bus914 ·
Yes those were used on Kombis eg. 76 model with a plastic rim.68AutoBug wrote:the 75-76 beetle headlamp Rim was chromed plastic with no adjusting screws... just the bottom screw hole that holds them on...
these were also used on Kombis...
