hey all, my name is Adam, im in campbelltown NSW, my number is 0401 55 40 49 and here i have my set of wide 5 disc brakes for king and link fronts (may fit ball joint if you change bearings)
they were from the first batch that vintage vee dub made a few years back... have only had 1200 miles on them and are basically brand new, no visable wear to discs or pads and will come with the hoses, bearings and adapter brackets.
These are not the cheap 2 piece sets, the discs are one piece, much larger then normal and run commodore callipers so pads are cheap and easy to find. they also do not mess with the offset like most of the other kits out there, they are actually 6mm narrower than standard offset so are great for anyone with aftermarket wheels which might rub or if your car is very low...
i love them and really regret the sale, iv been doing everything possible to keep them on my car but the current set up im working on will not incorporate them... my loss is your gain. They are brilliant and provide unbelievable braking performance.... Best thing is that they are completely bolt on and require no mods at all.... not even the master cylinder....
im after $1000 for them, Boris sells them for 1300-1400 in his shops so its a bargain.... my loss is ur gain...
cheers adam
polak ·
