Hi guys,
This should be an easy question for you. The car is a 72 Superbug 1600, vacuum advance distributor. What I'm trying to establish is how to interpret the timing marks on the pulley and what the correct timing is for this particular model.
There are 3 marks on the pulley arranged like so:
The gap between the left mark (L) and the middle mark (M) is about 12mm. The distance from the middle mark to the right one (R) is about 4mm.
From what I can gather they are:
L = TDC
M = 7.5 deg BTDC
R = 10 deg BTDC
Is that right? If not, then what are they???
Now, for the second part of my question -- what should I set the timing at? Is the setting the same regardless of the timing method used, i.e. static vs timing light? If adjusting at idle, should the vacuum line come off or leave it on?
I spoke to a guy at a local shop and he got me all confused. Said the left mark (the one I should use) is 7.5 BTDC and the one on the far right is TDC!! With the engine cranking clockwise, this just doesn't seem right...
Bart
bartg ·
