All good in theory, there are many details beyond the 'getting stuff machined' so maybe a book or manual might help.
not enough info on bearings, best off measuring, there are many combinations of sizes, a good manual will tell you this, the mains go up in .5mm increments on the back and .25mm increments on the shaft, big end bearings also in .25mm increments. Your mains are .25 on the crank but that's all I can tell you, the symbol is KS from your description I think.
If it's been rebuilt recently, just hone the bores ( or get it done) and save yourself 3-450 clams for a new set, seeing your not machining anything, so outlays are minimal in case it goes BANG 馃檪 If you want new, Mahle #1, Cofap usable, AA questionable...IMO
Brazilian is OK for some bits not for some others.....some you have no choice, that's why checking, blue printing, balancing and checking again is necessary for a quality build, it's all about wear and tolerances.
You'll also need gasket kit, gaskets that don't come in the kit, sealers, oil, sparkplugs, lots of cleaners and rags etc, and plenty of time 馃檪.
Treat it as a learning experience and keep the cost down and what have you to loose.
Read Hellbugged's build and you'll see what it takes to build an engine properly.
matberry 路
