Just wondering which gearbox has the best ratios for an EJ22 running 17in wheels. Its going in a Kombi but I have no problem fitting a single sideplate Beetle box if that has the best ratios.
bajachris88 ·
u having rubber bands on the 17 inch wheels? or going tall tyres?
seagull ·
I think the one Humpty did had the single side gear box.
seagull ·
super bug ratio
OZ Towdster ·
091 Mark
blackbuka ·
hey seagull do you have adapter plates and flywheels available??
BlueV2 ·
I have an adaptor plate and flywheel for a 091 box conversion....and a modified Subaru starter that bolts straight up to it !!!
DylanTheDubber ·
Yes Single side plate superbug box is the best. it has the talest top gear ratio they goe quite well with a EJ22.
If it is going in a bus, then a 2 litre bus box will be a great way to handle the power. Albins gears will make almost any ratio you want. It bolts straight into the bus too.
ttriebler ·
Or you could actually use the Subaru 5 speed gearbox that was designed and made for the EJ22. No need for fancy Albins gears, custom flywheels and adapter plates. Here's a short video that gives you some idea of how well it goes on the freeway.
