aerials?
https://forums.aussieveedubbers.com/threads/8451/aerials
bugbum ·
My beetle never had a radio in it so it never had an aerial but i bought a new cd player for it so now i have to put one in. I don't really want to drill a hole in the body for one. Will one of those aerials that you stick on work??
Andy ·
What year model do you have?
My '73 already had the hole in the panel (front left) with a rubber bung. I put the arial there.
Otherwise in the Kombi I hung the arial across the front under the dash, works OK if I stay near the city.
:thumb
his@hervw ·
Why do ya need an arieal for a Cd player,tee hee😀😀😀😀😀
I have a stick on in the EH and it works really well. A lot of the modified ones in our club have the same. They are powered and amplified, so that is part of their success.
The only thing is they would be too long to fit across the Beetle windscreen and I don't know if cutting it will affect the signal.
It is a Bosch brand I got from Gary's Car Radio
kombi69 ·
I didn't want to drill new holes in my Kombi either, all pretty well original.
I got around it by removing one of the bumper bolts and making up a simple angle bracket and using an aerial that usually mounts on a horizontal surface. Brought the cable up through the handbrake hole in the floor to avoid another hole. Works great and cheaper than the side mounted Kombi or Beetle style aerials. You might be able to do something like this with a bracket mounted at the front running board bolt, make sure the door is clear of bracket and aerial when you open it.
Come on, a hole here and there doesn't hurt anything.... at least its NOT a rust hole.... Early beetles usually have the antenna mounted on the front side 1/4 panel just in front of the door hinges. the later ones have a plug , in a hole in front of the LH Side of the windscreen... or You can always put one just back from the windscreen in the centre of the roof... If You shorten an antenna, there should be an adjustment under or behind the radio to trim or tune the antenna in to the station's frequency.... :bounce:bounce:bounce:bounce:bounce:bounce:thumb:thumb:thumb
Back in the 1970s... Mitsubishi Galants (sold as a Chrysler Galant) used the complete boot lid as a Radio antenna... the boot lid was insulated by rubber washers and plastic bushings. and it worked great..... I wonder why it isn't still used... I suppose it was NO good in luxury cars that when the radio is turned on the antenna automatically raises.... so when the Radio was turned on the Boot Lid would Open...... but it wouldn't close when the radio was turned off..... I suppose the front bumper on a beetle would be the easiest to insulate from the rest of the car..... Interesting I must say....:bounce:bounce:bounce:bounce:bounce:bounce:bounce
[Edited on 15-7-2003 by 68AutoBug]
Robo ·
My friend has one on his splitty under the front bumper, works well, although the stick on ones sound good never seen one but if it works OK that may be the way to go if yoiu dont want to drill holes
R1rob ·
Dont drill any holes!
Cut the antenna coax about 3 inches from your head unit.
Strip the coax back to the centre conductor for almost the whole length.
Whaala!
I get MMM Melbourne past Colac.
No Holes:thumb
65busser ·
A nice period antenna looks a treat.
It's hard digging holes in it, but you can always fill 'em if you get the guilts that bad.
geodon ·
My K/G has one & the static is awful. Yes I have a filter. I don't like putting on the bumper.
Has anyone tried putting one along the inside edge of the bumper? What works, the length of the antenna or does it have to point up in the air?
Aaaah crap! Just saw your post Robo! Can you find out what your friend used as an aerial behind his bumper?
[Edited on 16-7-2003 by geodon]
ByronBug ·
:sandrine
I have a 61 beetle which when I bought it,
had a old yukky side ariel.
So I bought a new one, after to & fro-ing
back to the shop finally got an old steel one, in fitting with the car settled on old style steel one.
Yes I had to cut hole bit bigger for it.
But does like better.
Now after years it is rusting (salty air here) so may have to search for replacement soon.
I too have nice stereo system in Bug...
& that ariel works great.
Judy (o\|/o)
mattie ·
heres an idea we didnt want to drill holes either go to a good car audio shop and ask for an anti distort thing that plugs into your stereo and then plugs in the aerial cord but the good thing about this is you dont have to have an aerial you can just use the anit distort thing it works great
cheers mattie
Bugged Again ·
this topic was covered previously, last year i think.
One of the better suggestions was to mount an electric aerial in the grille above the engine hood.
when it is down you don't see it, whemn it is raised in comes out between the slats.
mattie ·
the thing i was talking about is a suppressor it works excellent
cheers mattie
