Lots of VW Beetle Parts.
https://forums.aussieveedubbers.com/threads/84773/lots-of-vw-beetle-parts
71-BEETLE-SEDAN ·
Lots of random parts, Located in Mittagong NSW and will post at buyers cost and pick up is available.
1 Michelin XZX for sale. It is brand new and still has its size written on the tread. Its a 165/15.
It is on a VW rim 4/130 and can be changed to another rim for $6 if the rim is supplied. otherwise it can be sold without the rim for no extra cost.
These tyres can cost over a hundred dollers per tyre. This tyre is $100 plus postage.
Next i have 2 ball joint disc spindles. They are stock spindles and offer no drop in height. They are both in good gondition. Only have photo of 1 but they are $45 each or $80 for both.
I have 2 backing plates off a ball joint bug. Both very straight. $10 each or $15 for both.
Here is 4 torsion arms from a ball joint bug. 2 upper and 2 lower. $50 for them all.
1 Non superbeetle steering box with short rod. Good condition. $75.
71-BEETLE-SEDAN ·
Also have 1 set of pedal covers for a 71 manual. $5 for them all.
I have a header off a 1600cc motor. Not sure of brand but think its empi. $30.
Sway bar rubbers and clips for a stock ball joint sway bar. $20. Sway bar and rubbers and clips. $50.
Stock vw beetle shift knob, black, good thread. $5.
1 number plate light for whale tail. $5.
2 tailight bulb holders from a tombstone lights, bulbs included. Reverse lights too. $10.
1 rear decklid lock. $5.
1 Beetle washer bottle with clips and hoses. $10.
2 eccentric adjusters for a ball joint bug. $20.
Seals for torsion bars, all four inc. $15.
2 full bundles of torsion leaves for ball joint bug, $75.
A stock muffler off a 1600cc with custom tailpipes, 52mm stainless steel tips fully welded to muffler box. For heaters. $30.
1 brake rotor. 4x130 good disc plenty of meat. $30.
1 set of disc bearings for ball joint spindles. $10
1 Ball joint bug beam, stock, not narrowed not lowered. $100.
2 dust caps for disc brakes, 1 drivers side 1 passengers side. $3.
Nuts and grub screws for torsion bars, all there inc grease nipples. $5.
1 pair of running boards from a 64, no rubber or moulding on them. They have had rust removed and coated in primer and then bogged and sanded, now in grey paint. $50.
8 wheel bolts. Stock vw bolts. $10.
Photos soon.
silver ·
tyre does not look Brand new at all can you post up a pic of the date stamp on the tyre
71-BEETLE-SEDAN ·
No sorry tyre isnt brand new, bad wording on my part, the tyre is unused. They can sell for over $120 new and more, vw54 sold a pair a while ago on here for i think about $100 each.
71-BEETLE-SEDAN ·
Forgot to add can taxt me on 0407432787 or pm on here, im on all the time sowill get pms easily. Cheers Josh.
