joss ·
Need 4 new tires for my '66 type 3 square. any recommendations ie. Brand and where to get them. Im in Bondi!
https://forums.aussieveedubbers.com/threads/84839/tyres-for-type-3
joss ·
empi ·
joss wrote:Need 4 new tires for my '66 type 3 square. any recommendations ie. Brand and where to get them. Im in Bondi!
joss ·
joss wrote:Awesome thanks!! Its not lowered and they are stock wheels.
Talking to some tire places and one of them said that if you put tubes in a tubeless tire it wears the tube. Has anyone had that experience.
i would only go down that path because the tubeless types are more readily available.
BRUTUS ·
1500S ·
I had to beg the tyre place to put the radial tubless on the 64 Notch for that reason. With normal driving I doubt if I'd roll them off but it is the law. Tubes in the radials are a pain in the ass!BRUTUS wrote:Yes Tubeless are best on modern rims, BUT
You may NEED tubes if the rims are not "Tubeless Rims". It may be evewn more dangerous to use tubeless tires on those earlier rims.. than to use tubes
There is an inverted ridge or "hump" where the edge of a tubeless tire sits INTO on the tubeless rim. The changeover was in the 60's. You can tell instantly once someone points it out to you. The tubeless type is called the "J type rim". So if it has "J" next to the rim size stamp it should be right, eg. "4 1/2 J x 15" If the ridge is absent, USE TUBES!!!
joss ·
