Few help because I鈥檓 going to be crazy馃槵馃槵馃槵馃槵
After a new rebuild that I had made in EJ20NA 125hp i thought it鈥檚 time to place an oil pressure gauge in order to see if everything is normal.
I took from friend a sgear gauge including valve, working at 7bar.
All good up to here!
Then I cold start the engine and see oil pressure 6.0bar!
Beautifully I say鈥hen progressively and without having oil temperature gauge, the pressure starts to fell progressively (with exterior temperature at 37c) and after 15-20 minutes reached in 1 bar and afterwards.................. the needle stuck in absolute zero!!!!!!!!!!!!
Warning oil light has not turned on and when I accelerated the gas pedal, for example the pressure went up until 3.5bar and had roughly 3,000 turns.
When however I had no gear in transmission or I stopped the car then the needle with difficulty it is above zero or zero.
What the fu$#%^@k is going on here, with introducing brand new OEM Subaru oil pump and semi synthetic oil 10W 40 Fuchs.
Any suggestions please?
Rgrds,
Jim
Bugaru03 路
