EMPI 5 Spoke Wheels - Tyre Advice
https://forums.aussieveedubbers.com/threads/84862/empi-5-spoke-wheels-tyre-advice
karmanngirloz ·
I have a set of empi 5 spokes and was wondering whats the best tyres to get. I have seen ghias with a set of Yokohamas but the tyre looks pretty close to the body. Is there any rules in the esafety check about cleareance between the tyre and body?
empi ·
165s on the rear, they will bolt on if yr car is pre 64 (Thinner drums) later u will need an axle swap, or jack up the car to get clearance.
newghia ·
i have 195 / 50 / 15 yoko's on mine & yes it is close to the gaurds, look for something a little narrower
Nath
Tazz ·
175/65/15 nankang's.... i'll post some pics of the square when the new ones are fitted sautrday.
these are 205/60/15's one rear and 205/50/15 front
these are 165/80/15's on the square now but changing
Tazz
empi ·
The square has the thinner drums hence being capable to lower, the fasty would rub on the tyres if u were to lower.
Here is my 63 with 5s
Beerboy ·
Its for a karman ghia ;-) 165x15 which are the standard tyre I expect you have on it will fit the 5 spoke. more modern tyres are better as they will be wider and give you more grip. On the note of clearance I don't think any blue slip place will worry as long as you look safe.
welcome to the forum by the way
empi ·
Tyre tread is the main thing they look at , depends on yr gearbox axle tube length (Short up to 67 longer 68 +) i haave fitted 185/55/15s on a lowered Karmann with 5s without too much issue..... keeping in mind all KGs are hand built and body work can differ.
Tazz ·
empi wrote:The square has the thinner drums hence being capable to lower, the fasty would rub on the tyres if u were to lower.
Square has all 67 fastie brakes on it..... the 62 drums are crap.... lol
Tazz
