liam66 ·
So if I've replaced the stock subaru blow off valve with an aftermarket (non plumb back) BOV, then I wont need the vacuum controlled bypass valve that plumbs back to the resonator box? ( I hope not, 'cause i cant find it)
https://forums.aussieveedubbers.com/threads/84892/bov-bypass-on-ej20t
liam66 ·
seagull ·
liam66 ·
Jak Rizzo ·
liam66 ·
It'll have one, just wont vent back to the airbox or resonator box.Jak Rizzo wrote:I was always under the usumption that running without a blow off valve can damage the turbo as the back presure has no blow off valve to vent.
jak
Its not good for them but all the boy racers are doing it nowJak Rizzo wrote:I was always under the usumption that running without a blow off valve can damage the turbo as the back presure has no blow off valve to vent.
jak
colonel mustard ·
JVLRacing ·
😂😂😂seagull wrote:Yawn , what motor
+ put the stock one back on its better
trickysimon ·
71-BEETLE-SEDAN ·
