psimitar ·
So as the title says where can I buy some inertia seat belts for my 59 Bug apart from the scrappies?
https://forums.aussieveedubbers.com/threads/84961/inertia-seat-belts-where-to-buy-in-oz
psimitar ·
barls ·
bajachris88 ·
pod ·
squizy ·
psimitar ·
As per ADR regs I can place a 4mm thick plate a minimum of 3750mm in area within the B post and above the heater channel to mount the belt too 🙂squizy wrote:You will need to check with your seatbelt fitter to make sure you can legally fit inertia reel belts to your '59. Pretty sure you can only go static on that age.
