I got a new set of Scat chomoly 8mm case and head bolts but now Im a bit confused as to the location of the bolts.
The kit I received appears to be right looking at the catalog pic.
9 Long bolts
4 short bolts
3 mid length bolts.
My problem is where the hell do they go
I think it should be :
8 long bolts along the bottom of the heads (4 each side)
4 short bolts in the middle of each head up the top (2 each side)
3 mid length bolts on the top of each head on the outside???
1 Long bolt on the top outside of a head but which one???
Its the extra long bolt where should it be and why not four mid length bolts if anyone has any idea I would appreciate the input as I want to get this together tomorrow.
My memory is getting dim but one of the outer top studs, on #3 I think, the insert in the case is sunken in.
The extra long bolt goes in #3 top foward location. The later cases have a deep #3 stud that has the thread deeper in the case to prevent cracking or pulled threads.
Surfsup ·
Thanks guys, that would explain it, my case originally had 10mm bolts and had case savers installed when I had it machined but obviously the #3 forward bolt is not as deep as the cases that came out with the 8mm bolts factory, I am presuming it should still be ok to use the last long bolt here
You need to either have the insert sunken in to the correct depth or find a short stud.
Surfsup ·
Thanks mate, or I could use your favorite friend " the angle grinder"!!! lol . No I do have some extra 8mm studs so I will use one of them.
Cheers guys thanks very much for your help greatly appreciated.
