Facet fuel pump
https://forums.aussieveedubbers.com/threads/84998/facet-fuel-pump
ancientbugger ·
My baja has a facet fuel pump fitted does anyone know wat pressure they put out.
Mick
ancientbugger wrote:My baja has a facet fuel pump fitted does anyone know wat pressure they put out.
Mick
not sure... but most people use a pressure regulator with all fuel pumps..
makes the needle & seat work with less pressure..
ancientbugger ·
He just found out Lee and we've already got one on order..........BTW my son Mick uses my login🙄
many of the pumps only go to 10 psi
but as You only need 3-4 psi...
its better to have a regulator...
PS: tell Your Son to get His own name... lol 😂
General_Failure ·
My pump runs at over 8PSI. I needed a regulator. Bad things happened.
mackaymanx ·
Several pumps to choose from.
So, If You have bought a 40104 pump You will have no worries..
I did have one of these before gave it to My son..
Not sure which one it was..??
they all look the same though...
General_Failure ·
All of this has prompted me to try reviving my old leaky mech pump. I think the casting is warped or something. My facet knockoff is closest to the 40107. If the reg goes funny all hell breaks loose. My Weber has a fit!
ancientbugger ·
It's funny what you find out even when you think you've done a thorough investigation. When I ordered the pump a couple of years back I distinctly remember checking on pressures and making sure it was the equivalent to the standard mechanical pump which I had been assured it was and remember being told that Facet only made one, now Mackaymanx has destroyed all my previous notions. I will crawl under my sons car and see if I can find a bloody number even though I've already ordered a fuel pressure reg. for it😠
