The 1600SP thick stud motor in my splitty ute is down on power. The past few mornings when I start it, there is a loud clattering from 3/4 head which goes away after about 10 seconds or so. The engine warms and idles fine, but when I drive it and put the gas down it feels like there is a miss.
I've checked its getting good spark at all plugs, checked all the ignition and the carb seems ok.
I was going to pull the rockers off and torque up the lower head bolts to 23ft/lbs but you can't get to the top 4 bolts.
Anything else I can do to check it before I pull the engine and pull the tinwear off to check the top bolts?
matara ·
