New 1916cc Turbo Type 1 Engine. (PRICE DROP!)
https://forums.aussieveedubbers.com/threads/85125/new-1916cc-turbo-type-1-engine-price-drop
VWFREAK ·
New 1916cc Turbo Volkswagen Type 1 Air Cooled Engine. (Under decklid type)
PRICE: $7600
SELLER: Peter
Ph: 0434667343
Please contact me on mobile to discuss the engine etc, posts and PM's may not be answered due to my work commitments.
- T3 Turbo
- 38mm Progate wategate
- 1 3/8” 16 gauge ceramic coated headers and pipes
- True 4 into 1 collector
- High flow ceramic coated T-pipe
- 69mm Scat Crank
- 040 heads
- Holley 350cfm 2 barrel (Adjust-A-Jet)
- Chromalloy Rods and lifters
- Heavy duty full flow oil pump
- External 96 fin oil cooler with thermal fan
- Large extended sump
- Dual Valve springs (require fitting)
- Bolt-on EMPI rocker covers
- AS41 case, reconditioned
- Chromalloy retainers
- Compression 7.5:1
- CAM LCB1 (similar to a 110 engle, but turbo specific)
- PROCOMP Turbo locked out distributor
- PROCOMP Multi Spark Ignition System CDI
- PROCOMP ignition Coil
- PROCOMP Fuel Pump
- PROCOMP Regulator
- Chrome tinware
- Boost Controller
- Comes with all gaskets, sealants, clamps, silicone and cables required
- Stage 2 heavy duty clutch and lightened flywheel
- 12v alternator
All items are brand new
This engine was built to suit my street / strip project which has now ceased. The 1915cc was built by CBB in NSW and has only done 1000km in a previous daily driver I owned and then stored pending turbo upgrade and street / strip project build. The turbo kit is from Lowbugget.com (T1600 kit), and has never been used and only fitted for mock ups. Requires very little finial assembly.
Average power output: @ 8lbs = 160+hp
@ 15lbs = 240 +hp
This kit can easily supply up to 300+hp
http://www.lowbugget.com/turbo_new_page_link.html
Main Picture listed is from the lowbugget website, all others are of the actual engine.
The engine and other add-ons and accessories owe me much much more than the asking price, so please don't insult me with low ball offers.
Grab a bargain, my loss is your gain!
Please contact me on 0434667343 for any further information.
link not working???
Cant find the link??
Ollie ·
Sorry for being a twerp, but can't see asking price? Or is in POA?
Looks fantastic though and would certainly put you in your seat... I want 🙂
VWFREAK ·
As per the ebay listing. Check it out! 😀
VWFREAK ·
Link becomes active @ 8pm tonight as per the post details 🙂
Camo ·
PM sent.
Kev
VWFREAK ·
Thanks Kev, appreciate it 🙂
VWFREAK ·
bump
VWFREAK ·
bump
VWFREAK ·
RE-LISTED DUE TO NON PAYER 🙁 So here is your 2nd chance if you missed out the first time.
VWFREAK ·
BUMP
VWFREAK ·
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=190434126286&ssPageName=STRK:MESELX:IT
VWFREAK ·
bump😉
55panel ·
would this fit into a 55panel spilt? been keeping an eye on this
gaz58t2 ·
So is this motor still up for grabs
E Bay seems to think it has finished
Camo ·
Ring the seller and ask. His number is in the add at the top.
Kev
VWFREAK ·
PRICE DROP!!!!!!
The engine is still available.
VWFREAK ·
bump
