hey
when iu let the clutch out on my fasty it starts to shutter the whole car like its kangaroo hoping(or whateva they call it) does this mean i just need to adjust the clutch or is it the throw out bearing or the whole clutch system??
im poulling the engine out so i wont to fix the problem know!
rhys
my guess is either
oil on plate
warped plate
shot springs
Either way i would be prepared for a new clutch set up
Is oil dripping where the bell housing joins the motor?
KruizinKombi ·
As blue said. :thumb
When you replace the clutch, spend the extra time and money to get your flywheel machined as well, just to ensure that everything is true. 🙂
BiX ·
also check ur engine mounts. Had this poblem on mums car. The engine mounts had gone and allowed the engine to twist , and pull the cluth cable releasing the clutch, then the cable would unload and the clutch would take up etc.
You may also need more of a bend in your clutch cable outer, between the pan and the gearbox. This is a common problem.
kombi_kid ·
the guide tube didnt have much bend in it! so i brought a new one and got another few washers!! but also the throw out bearing has a warn face and has a few mm play in the bearing!
does anyone know if a clutch off a 1500 beetle will fit upto a 1600 swing axle early type 3 box???
there is a little bit of oil in the gearbox so im not sure weather to do the rear main or not???
rhys
kombi_kid ·
hey
well i got myself a bargain a brand new sax(sp?) german made clutch with pressure plate and a throw out bearing for $50!!!! the guy even threw in a gasket kit some points and a swedish made roof rack!
hopefully no more shudder!
rhys
