berg style midmount question
https://forums.aussieveedubbers.com/threads/85159/berg-style-midmount-question
funbug ·
Do you put the midmount directly against the gearbox casing or against the lower nuts with another set of nuts?
hellbugged ·
done it both ways.......you will need longer studs
funbug ·
hellbugged wrote:done it both ways.......you will need longer studs
If you mount it directly against the casing won't it inrease your chances of oil leaks? I am aware of the need to fit longer studs.
I did mine like this
Newt ·
Bizarre
Does this sit further forward on the gear box than the Berg mount?
Newt
funbug ·
Bizzare are those studs which fit the cradle flush against the gearbox casing?
Euro_67 ·
They look like cap head allen bolts.
Yes - we took the studs out and replaced them with allen bolts
funbug ·
Bizarre wrote:Yes - we took the studs out and replaced them with allen bolts
Do you have any problems with oil leaks?
Just put some Leak-loc on the threads, I did this with my 70 bug, it has the same setup
