bugzla wrote:wat do you think .......... was using a wasser boxer dissy set up a few years ago but no longer have it nor does anybody make them any more i now have a petronix 1 with gt 40 w8ac that keep fowling and im turbo charging soon has any body got a setup that works atreat and throws awesome spark .
STEVO
I had a DSE Jaycar kit.. HIGH ENERGY IGNITION SYSTEM..
using a standard coil and points... was fantastic...
engine started first kick.. every time... excellent kit..
it put 32 volts into the coil...
lots of options in it too...
the points only switched it on & off.. never burnt..
until it burnt out... the points had worn down & shorted out... ??
they had a plastic rubbing block... instead of bakelite..
I have a pertronix to put into My New SVDA Bosch dissy and I will either fix the old HEIS or make up another one...
[lucky I had a spare]
the spark plugs could be wider gapped too...
