Conversion from 5 wide to Porsche.
https://forums.aussieveedubbers.com/threads/85310/conversion-from-5-wide-to-porsche
vicelore ·
Hey guys.
Well looking at putting some fuch`s on the type 3 and am after some info on the required studd pattern change.
Cant seem to find anything by searching..
any info or links on the process would be greatly appreciated.
Cheers Vice
Buy new uniform thickness blank rotors and get them drilled for 5 x 130 PCD
I do know Sherman has them
At Valla they were about $100 per drum + $85 for drilling and studding
I am sure others in Melbourne do it - but count on $750is for all for wheels
zayus ·
Hey Hey Vice,
The stud pattern for Fuchs - 130 x 5
The offset for Fuchs rims varies -
Original Fuchs
15 x 6 - 36mm
15 x 5.5 - 42mm
15 x 4.5 - 42mm
Flat 4 replica Fuchs
15 x 5.5 - 45mm
15 x 4.5 - 45mm
The higher the offset, the closer the wheel sits to the shock tower, eg: 42mm
The lower the offset, the closer the wheel sits to the guard, eg: 36mm.
Zayus
vicelore ·
Thanks for the info guys..
Is this Sherman a shop ? or a guy on here ?
vicelore ·
Where would you guys buy blank rotors in Melb or over the net ?
Cheers Vice
hellbugged ·
classicveedub have em
or sherman....
http://www.volksconversions.com.au/
vicelore ·
Cheers Man.. I found volksconversions after a bit of a google. 🙂
reub ·
Has anyone used the gear from Sherman?
How is the quality/longevity?
Pics??
ian.mezz ·
