Aussieveedubbers · Bugs
Fitting 17 inch wheels to Beetle
https://forums.aussieveedubbers.com/threads/85365/fitting-17-inch-wheels-to-beetle
Chop Top VW ·
Hi Everyone,
Has anybody fitted 17 inch wheels to a beetle.
I wanna fit 205 x 40 x 17 tyres on 17 x 7.5 wheels
The car will be droped 2.5 inch using drop spidles on the front
The front beam is standard.
Could anybody tell me if that would be ok or do i need to stick to 15 inch wheels.
thanlks
Yep - all depends on the offset
I run 205 on 6" up front and 225 on 7" on the back
All under stock guards
Personaly - i think 205 on 7.5" is a bit tight
have a play here
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.rimsntires.com/rt_specs.jsp
bugzla ·
i was running 225 all round on 17 x 7 verde dimonds
vwo60 ·
hi,
you do not say what car you have, if it is a trailing arm front end you will have trouble running a 7" wheel under standard mudguards on the front as it will hit the trailing arm when you turn the wheels, the photo's show my cab fitted with a 7" front and a 8.5" rear,the fronts look good but have to many fittment problem, i could only fit a set of 16" x 6" on the front with a 195, 55 tyre, on the back is a 7" x 16" with 225, 55 tyre all under the guards with no issues
7.5 is a tad wide for the front if you want to turn corners and under the current RTA rules you can only run over 7 inches wide if the car weighs in at over 1000 kgs.
good thing mine now weighs 1004kgs 😂
Joel wrote:good thing mine now weighs 1004kgs 😂
Hi Joel
Unfortunately as you car was made after 72 you come under different regs, you can only go 1.5 inches wider than the widest optional wheel = 7 inch.
Brian ·
it goes on the unmodified weight
all bugs are under 900kg
Hi Brian
No its finished weight of the car.
jhp1 ·
You can fit 17x7.5s under the front depending on offset 205s will work until you go stupid low
You may need to run a narrowed beam, what years your car?
As to it being legal no 😀
cam070 ·
vwo60 wrote:hi,
Can i ask what offset whhels you are running? ie the 7's as that's what i'd like to run on my bug.
Chop Top VW ·
i have a 68 chassie with a 64 body, 5 x 130 i think the offset is about 40
cam070 ·
Chop Top VW wrote:i have a 68 chassie with a 64 body, 5 x 130 i think the offset is about 40
Are you also saying you are running 17x7's?
Chop Top VW ·
no, im asking if it can be done 😊
vwo60 ·
Hi,my experence tells me that you cannot run a seven inch rim on the front under a standard guard on a trailing arm front end, the sevens on the convertable hit the shock and the trailing arm and had hardly any turning radius, if you narrow the beam you will have all the problems that having incorrect geometry will bring to the front end of the car, i have 7" x !7" on my 60 beetle but they required the use of wider guards to get the to fit to the car, track on the front is only 18mm over standard
7" will work on a balljoint front end with a 40offset but if you want a turning circle better than a bus you'll need to narrow the front end about 2" and run some spacers
Ive tried the 17x7et42 rims on my old 70 bug, fitment was perfect but like mentioned above they rub on the trailing arm with a stock width beam when on full lock
vwo60 ·
Hi, narrowing the beam and running spacers to fit the wheels under the guards raise a whole lot of problems with the geometry of the front end, the scrub radius will be change substantiality, you will increase the bump steer and tramlining not to mention the increased wear on the trailing arm bushes/ball joints/wheel bearings as you will be hanging the wheel further out on the suspension, narrowing the beam will not improve the handling of the vehicle either, the engineer i spoke to said that narrowing the beam to fit the incorrect offset wheel to the car would be illeagal as it changes the wheels relationship to the suspension,it's not as simple as just fitting them under the guards, the scrub radius is probably the most important thing that is overlooked when fitting wider wheels to your car, if you want the car to track well and not wander under brakes try to keep the track diamention on your vehicle as close as posible to standard diamention without narrowing the beam, the scrub radius is were a line drawn through the ball joints/kingpin and disects the tyre were it contacts the road looking from the front of the vehicle
Yet another good reason why I stick to my strut bugs
vwo60 ·
This also applies to the strut bug
cam070 ·
vwo60 wrote:Hi, narrowing the beam and running spacers to fit the wheels under the guards raise a whole lot of problems with the geometry of the front end, the scrub radius will be change substantiality, you will increase the bump steer and tramlining not to mention the increased wear on the trailing arm bushes/ball joints/wheel bearings as you will be hanging the wheel further out on the suspension, narrowing the beam will not improve the handling of the vehicle either, the engineer i spoke to said that narrowing the beam to fit the incorrect offset wheel to the car would be illeagal as it changes the wheels relationship to the suspension,it's not as simple as just fitting them under the guards, the scrub radius is probably the most important thing that is overlooked when fitting wider wheels to your car, if you want the car to track well and not wander under brakes try to keep the track diamention on your vehicle as close as posible to standard diamention without narrowing the beam, the scrub radius is were a line drawn through the ball joints/kingpin and disects the tyre were it contacts the road looking from the front of the vehicle
........seems like things just got more complicated. I was hoping to run 17x7's on my bj front end.
Go check out germanlook where 100s of people already have
colonel mustard ·
Joel wrote:Yet another good reason why I stick to my strut bugs
Heck yes. 🙂
bugzla ·
here was mine 7 x 17 4x130 stud pattern ball joint front
Chop Top VW ·
hi bugzla,
did you modify to fit the wheels, how much was it lowered.
bugzla ·
nope they were a straight fit, lowered by one adjuster all the way it was pretty rigid i would put 2 in if i still had the car..... as for the back readjusted the torsion bars a few notches and handled like a gocart
cam070 ·
What offset were your wheels Bugzla? And are you saying you didn't have to narrow your front beam? Also, did you get any fouling/rubbing when on full lock?
And it must have been fun looking for 4x130 wheels. I thought they would have been like finding fairies!
bugzla ·
still had a bit of rubbing on the inner cant really remember the correct offset sorry........ but the wheels where blank and drilled to suite, the hardest thing was covering the stud pattern and having enough meat on the outer of the stud circle but they fitted like a glove not bad considering
Most of those Vault rims are all et40
bugzla ·
they are a verde rim
Vault/Verde same diff
Funny if you painted your old one black, added Tbars and changed the rims to Fuchs it would be an identical twin to my old rotary bug before I put it all back to original panels
bugzla ·
well funny u say that it had fuchs on there hahahhahahahhahaha
vwo60 ·
Hi Bugzla
Nice job on your car, did the wheels rub on the lip on the mudguard, the wheels on my convertable on the previous page are a 6' x 16" with a ET of 50mm, with this set up you loose 34mm clearence on the suspension and loose 4 mm mudguard clearence , i could only use a 195/55/16" toyo maxium, if you use a 7' x 17' rim with a ET of 40mm you loose 37mm clearence on the suspension and the outside of the rim moves 27mm towards the mudguard lip, that is 24mm increase over my car, all of the diamentions are compaired to the standard wheel fittment, you can check any wheel fitment on the offset calculator below.
I removed the wheel and fitted a 3mm spacer and the tyre then would rub under braking and cornering, taking into account that my car has a 195 tyre and the smallest tyre available for the 17" rim is a 205 there would be a major problem in getting a 17" wheel to work under the standard guard successfully it's more than just not bolting them on.
