Camber Compensators
https://forums.aussieveedubbers.com/threads/85387/camber-compensators
utter buggery ·
Hey all,
Just wondering if Camber compensators will bring my rear wheels more upright on my bug? as it is fairly low and with the tyres sitting at this angle, tehy aren't going to do many miles at all!
Any advice is helpful.
Cheers, Jacob
vwo60 ·
Hi,
A camber compensator will have the oposite effect, it will apply force to the bottom of the axles and probably increase the negitive camber, if you want the car to handle you will need to raise the rear of the car so there is about 1 to 1.5 degrees of negitive camber and then you can fit the camber compensator
utter buggery ·
Thanks vwo60, so you're saying that the only way to straighten up the wheels is to raise the car again? I think I'll just let it be if that's the case haha 😂
HappyDaze ·
Depending on the way the comp. spring is set up. I don't think you need to adjust the torsion bars at this stage, you would find a great improvement if you fitted a comp. spring correctly, with the car the way it is.👍
The spring should support some of the rear end weight, and - if adjustable - can be tensioned up to give somewhere around 1 to 2 degrees neg. camber, depending on what you are doing with the car.
vwo60 ·
Hi Happy daze,
Could you please tell me how you set up the camber compensator, it is not disigned to carry the weight of the car, the weight of the car is disigned to be carried by the springs, if you use the swayaway style it preloads the axle and acts a negitive spring, depending on your rear end set up it can cause the rear end to end up with some negitive camber, the other style which has a loop around the axle does the same thing as you have to use a floor jack under both camber compensators to fit the centre bolt, none of the camber compensators that i have used can raise the car
HappyDaze ·
If you let me know your email address, Ill send some pics and explain - too hard for me to do it here.
Been mucking about with compensating springs for 50 years.🤪
Cheers, Greg
1500S ·
vwo60 wrote:Hi Happy daze,
The EMPI (??) ones from the 60s did actually take some of the cars load as Greg has said in his post. These are the ones with the straps around the axle tubes. They only had a small curve in them and the mounting cradle under the diff gave a downward force on the spring which in turn, pulled the axles downwards. It depended how much the springplates were lowered as to how much of the cars weight was supported by the compensator spring.
How do I know? Eveleigh Loco Works at Redfern turned out quite a few copies of the Empi bar in the later 60s!! 😂
DH
vwo60 ·
Hi 1500s,
i had a original empi years ago and still remember having to use a jack underneath the compensator to fit it to the gearbox when the car was on the flat, still is not the answer to utterbuggery's question
mine is "preloaded" on my car as well👍
HappyDaze ·
Check out the way Porsche and Mercedes Benz had their compensating springs set, and also F.Vees, and you will see how it SHOULD be done.👍👍
1500S ·
vwo60 wrote:Hi 1500s,
Maybe to clear things up, there looks like there are two types of Camber Compensator bars. The first one, Empi, I am talking about has a large cradle which is held in place with four of the diff studs. The bar has eyes at each end as a normal spring. To this attaches the webbing strap which goes over the top of the axle tube. There is nothing between the eye of the spring and the axle tube so there cannot be any upward or lowering force from the spring to the axle. Hence the compensator will have some of the vehicle load on it when the car is on it's wheels.
The second type (your "Swayaway?? type ) I have seen has nylon blocks on each end of the compensator spring which actually contacts and forces the axles upwards into negative camber so in that case there isn't any of the vehicles load on the spring.
So with all that, the type of compensator spring I am talking about (first type) could actually bring the wheels back towards zero IF the spring was strong enough.
Don't ask me what keeps the second cradle in place! We made the first type from slightly larger section spring steel as that was what the Railways had! The cradle was made from offcuts of 1/8" Stainless steel sheet.
http://vwplusvw1500.blogspot.com/2008/02/nos-empi-camber-compensator.html
DH
vwo60 ·
i still do not know why you would want to use any form of camber compensator to set the ride height of the car,that's the springs job,the only one that is adjustable is the hand made one that happydaze has made, the swayaway and the empi copy attach to the four eight mm studs on the side plates of the gearbox and have the mounting holes slotted, having owned both of the camber compensator (empi and swayaway) for general road use i have found the swayaway a better performing unit with a much better ride
1500S ·
vwo60 wrote:i still do not know why you would want to use any form of camber compensator to set the ride height of the car,that's the springs job,the only one that is adjustable is the hand made one that happydaze has made, the swayaway and the empi copy attach to the four eight mm studs on the side plates of the gearbox and have the mounting holes slotted, having owned both of the camber compensator (empi and swayaway) for general road use i have found the swayaway a better performing unit with a much better ride
The original question asked was:
"Hey all,
Just wondering if Camber compensators will bring my rear wheels more upright on my bug? as it is fairly low and with the tyres sitting at this angle, they aren't going to do many miles at all!
Cheers, Jacob "
In view of this I just added to Greg's statement that yes, it can raise the rear as the compensator spring if it's the Empi style will take some of the load. Do I use them now? .... no. A Commodore wouldn't look right with one on it and I don't think it would help! There is no reason to put one on my Notch these days but I did have one on a Notch in the 60s. There were handling benefits noticed on cornering and that was the main object of the exercise back then. The then normal was to lower the springplates around 5 degrees and then pull it back to whatever the compensators spring force was. As for anything technical about that 5 degrees who knows. That was what was being suggested at the time.
I now see that that bottom pic type actually mounts to the frame horns thus preventing any load on the transmission mounts.
As for "why would anyone.......? Simply I suppose is "because we could". If things aren't trialed, such as coil springs, we'd still be driving cars around with cart springs on all four corners of "normal" cars.
Hope that explains some of the reasons.
Also better add! If anyone is thinking of using the Empi type in the top pic I posted on a swing axle Type 3, think carefully. It's actually putting an upward force on the gearbox and engine and can crack the rear support mount on the body if the mount isn't adjusted right.
DH
Stephen62 ·
Hi everyone (new to the forum)
I used to have a 70 swing axle beetle with I fitted a rear bar to. It was like a sway bar, but straight. It mounted to the frame horns and loose bracketed to the axle springplate mountings. I was greatly suprised and happy with the huge improvement in handling. I figure that they made the rear like a progressive spring rate. When driving "normally" the flex didnt reach the brackets so they dont do anything, but on fast corners with body roll, they held the car upright.
Is this bar anything like a sway bar or camber compensator ?
Has anyone seen a bar like this ? - Most rear sways I see are more "u" shaped
Thanks for your help
zayus ·
Stephen, the sway bar you described sounds similiar to the old K-Mac sway bar, that I use to have my Beetle.
The K-Mac rear sway bar ran straight under the car - shock to shock. See very basic diagram!
Does anyone know if the the old K-Mac sway bar worked similiar to a Camber Compensator (CC)?
Have always been interested in getting another K-Mac sway bar, because I was told that a CC would ruin the gearbox, due to the stress it places on the mounts.
Today, thanks to DH, have learned that the "newer" style sway bar mounts to the frame horns instead of the gearbox. Might just have to order a Sway-a-Away CC.
Note: the Swing axle diagram is coutesey of FJCamper @ http://www.shoptalkforums.com/viewtopic.php?f=51&t=122651
