Aussieveedubbers 路 Type 3 and Karmann Ghias
rear quarter panel
https://forums.aussieveedubbers.com/threads/85412/rear-quarter-panel
zocstar 路
hi guys needs some info,
are the type3 rear quarter the same on the square and the fast back? and for all years?
thanx heaps
vlad01 路
nope 馃檪
All different between the models and also above/below 1970 was a tail light change.
zocstar 路
Thanx man, that screws that plan.
I thought the tail lights would be the issue.
On to plan b.
VW-VARIANT-L 路
vlad01 wrote:nope 馃檪
What's different between fastback and squareback rear guards ?
AFAIK these are interchangeable. pre-70 have the smaller rear lenses, and also differences between earlier models rear reflectors, but the metal is the same pressing.
Notchback are a completely different pressing due to the different air intake.
zocstar 路
^^So do you think I can use one from a 71 fastback?^^
But if not can someone help with..... Bum,bub,baaaaa.....
Plan b:-
http://forums.aussieveedubbers.com/viewtopic.php?tid=85423
cruiser 路
They are different on each model, not only different because of the intake but mostly where the rear part rolls over at the top.
The notch and fastback have a roll over to meet up with the boot lids (each are different) whereas the squareback has no roll over since it just meets the vertical part where the windows are.
VW-VARIANT-L 路
zocstar wrote:^^So do you think I can use one from a 71 fastback?^^
Plan b:-
Checked on a fasty and a squareback side by side, and they are the same shape rear fenders, so you can fit fasty panels to your squareback. The shape of the base of the C pillar is the same on both models.
I wouldn't fit a 71 fender though to your 69 as the stock earlier small rear lenses look much better. You can get panels from several VW shops in Melbourne, not sure about NSW though.
vlad01 路
Different shape where the rear window pillar meets the panel. 馃槀
I know, I tried it a few years ago. didn't fit
馃檯 Position of the pillar shape was 2-3" off.
So is there a plan "C"
Hutcho 路
As vw variant said. They will all bolt to your car. Notch had no side vents as air intake came over the back window and through the bellows. Up to you what rear tail lights you want to run but you run the risk of it looking like a bitsa if you cross the great model divide!
steve
matberry 路
Yep, fasty and square interchangeable, except the obviouse tail light differences with early and late model.
zocstar 路
Plan c? What's wrong with plan b? I think I have a bonnet.
And thanx everyone for their input.
