Just a quick qeustion, is it possible to cut the collar off an early model clutch and use it on a late model tranny? I assume no but I can't think of a reason why it wouldn't work.
Thank You
Nicolas
Yes you can, some diaphram pressure plates the ring is removable with a spiral lock, others you need to grind out the crimp that holds the ring on.
nicolasw ·
Thanks Matt,
Thought it should work but was curious if anyone had done it before.
