Hi guys, does anyone have any advice on who to take a 71 Beetle 1300 to, to have it lowered (front + rear)?? Don't wan't it to be panscraping low, but definitely low enough to tidy it up.
Also, what sort of cost would be reasonable to expect??
I live in NSW (rural) but don't have a problem with taking the car anywhere in NSW or even in Victoria if necessary.
Any advice greatly appreciated.
Thanks,
Kris.
Barnabie wrote:Hi guys, does anyone have any advice on who to take a 71 Beetle 1300 to, to have it lowered (front + rear)?? Don't wan't it to be panscraping low, but definitely low enough to tidy it up.
Thanks,
Kris.
Can be very expensive to have the front lowered...
as the front has to be pulled apart...
and adjusters fitted [welded in] so You can adjust the front up & down as You want
the rear is also time consuming... so costly..
but no parts needed.. although I would replace the torsion bar rubbers at that time...
[rubbers would be the cheapest part]
shop about for prices...
Phil74Camper ·
Canberra VW Centre is probably closest to you in Wagga. Give them a ring on (02) 6293 1941 and ask for quotes.
What's wrong with the stock ride height?
Phil74Camper wrote:What's wrong with the stock ride height?
Everything! 😂
Barnabie ·
Nothing is wrong with it I guess, I'm fitting some rims and just don't want it to end up looking like a 4WD afterwards. If I wasn't fitting rims I wouldn't bother changing anything.
empi ·
Barney , like a said, get a premade narrowed adjustable beam and bring it to me!!!
Snap Crackle Bang ·
If your new rims increase the rear track at all you will find that the rear suspension will sit a little lower. (I assume it's a swing axle)
Barnabie ·
Yep - but the new rims are still same size as originals.
Its more the front end that sits a little high for my liking.
Phil74Camper wrote:Canberra VW Centre is probably closest to you in Wagga. Give them a ring on (02) 6293 1941 begin_of_the_skype_highlighting (02) 6293 1941 end_of_the_skype_highlighting begin_of_the_skype_highlighting (02) 6293 1941 end_of_the_skype_highlighting and ask for quotes.
the front always looks too high on a beetle... IMHO..
especially on the later ones 68>>
1302 & 1303s worse... IMHO...
but great if You drive on country roads etc... lol
then again, I hate the narrowed front beam look... lol
PS: front just looks too high...
Barnabie ·
You're right Lee, the front is definitely too high ... but then again once I lower that the back will probably look too high!
As you say, it does have its advantages when driving in regional areas, but the roads around here aren't too bad, and its not my daily driver anymore.
Anywho, I'll lower the front with a beam swap and reassess the rear - but I dare say it'll get the treatment too.
Barnabie ·
This looks nice and tidy, but not excessively low (IMO).
Barnabie ·
Love this photo ... reminds me of holidays with the beetle ...
Nice ride height too (IMO)
Paulc1964au ·
Here are before and after shots of my rosie, i had the front lowered by two and a half inches
I had the guys from RAW install drop spindles and readjust the rear
Now thats noice! 👍
Barnabie ·
Paulc1964au wrote:Here are before and after shots of my rosie, i had the front lowered by two and a half inches
That looks way better than the b4 photos 👍
Tidier, but still practical. 👍
Would you possibly PM me the details of the cost?
Much appreciated,
Kris.
Paulc1964au ·
dropspindles were approx $300 and i paid approx $200 for labour.
It is also important to get the tire combination right as well i have 195 x 65 x 15 on the rear and 175 x 65 x 15 on the front.
The front tires are rubbing on full lock but hoping once i put decent shocks on the front it will improve
zayus ·
Paulc1964au wrote:dropspindles were approx $300 and i paid approx $200 for labour.
Paul,
That is the best piece of information I have read, regarding drop spindles and tyre size.
Thanks,
Bryce
I'd call that red 1200 beetle on gas burners excessively low
thats a 2 spline drop at the back, without notched spring plates a shopping trolley would have more suspension travel than that thing.
Doesnt mean it don't look hot though
Paulc1964au ·
Paul,
Thanks,
Bryce
Thanks Bryce,
I did a fair bit of research and the most important lesson learnt is the V65 is a percentage of the width of the tire. So the total diameter of the rear tires are 640mm and the fronts are 590mm which helps with reducing the possibility of the tyres rubbing on the front guard.
The smaller dimension of the front tires has had a minor affect on the speedo accuracy but so far it seems to be very marginal.
At the end of the day tire size etc is personal choice but I am happy with how Rosie looks and feels. I have had a lot of positive comments from hose who have seen her before and after
Barnabie ·
Joel wrote:I'd call that red 1200 beetle on gas burners excessively low
You're probably right, but hey, isn't that what seats have springs for 🤪
lownsneaky ·
dont hack the springs what ever you do lol nothing but dramas
Paulc1964au ·
Just an update the boys at RAW installed gas shocks on the front and adjusted the camber and no more rubbing
Johnnie B ·
The cheapest way to drop the front would be to get a set of drop spindles. This will drop the front 2.5 inches. It is an easy job if you are mechanically minded.
The rear end is also pretty simple as well, again if you are mechanically minded. You can either move the spingplates a couple of splines on the torsion bars or get adjustable springplates. It only took me an hour to drop the rear end on my 66.
If you do go for a new narrowed beam. I would only get a two inch narrowed one. Anything narrower, you will need new tie rods and you may not be able to run shocks on the front.
barls ·
hey jonny b your about 8months late with that post.
Last time I checked quality dropped spindles were far from cheap.
Cheapest way to drop the front of a beam bug.
Remove front end
Find a mate with a welder
cut and turn anchor points
weld back together
profit
Johnnie B ·
Joel wrote:Last time I checked quality dropped spindles were far from cheap.
Remove front end
weld back together
profit
California Import Parts have 2.5 inch drop spindles for $89.95 Canadian for a pair. I have no idea about freight though. Guess I am lucky that I only live 30mins from their warehouse!
Telebeetle ·
Yo Dudes. New to this forum and although I only visit every now and again, though I needed to register and comment.
A '71 beetle is a 1302. Meaning it has a strut front end and independant sus at the rear.
What happens with these cars is the rear torsion bars sag over time but the strut front end does not.
This is a real problem because if you're cruising at freeway speeds, the air gets under the car, lifts the front end and the steering gets too light. Very dangerous.
My advice. Lower the front springs. It is illegal to cut springs, so I would advise against that. Be sure to cut the springs from the top where the coils are bunched. The obvious way is the spread out end but that is the progressive end and if you lower from there, the suspension will become very tight and bumpy.
Leave the rear alone it will be just right after the front end is lowered. In fact, your car will have a wedge type shape against the wind. That will nail it against the road.
My Beetle is the same. '71 Superbug.
Telebeetle wrote:My Beetle is the same. '71 Superbug.
Telebeetle, not sure if you're from aus or not but they are 2 very different cars.
Yours is a 1302 super which is Mcpherson strut front and IRS rear, the OPs car is a 71 1300 beetle which is balljoint front, and swing axle rear.
They sold both beetle types from 71 onwards in most parts of the globe.
If you wanna lower a strut bug on the cheap don't cut the springs, reweld the bottom spring cup on abit lower.
Newt ·
Could be wrong, but I thought bugs handled better when the nose was a bit higher than the rear....
Wired1 ·
This is my 1974 1500 beetle which is ball joint front beam and swing axle rear:
... and this is my recently sold 1966 beetle that is ball joint front beam and swing rear:
The cheapest way to lower the front on either a ball joint or link/king pin front is to cut the beam and turn it. If you can weld it will cost you only time.
If you can't weld and you have a ball joint beetle then the dropped spindles is probably cheaper than adjusters as they are a bolt in part. On a link pin/king pin front it is expensive to fit them and you will probably need to get it done as the king pins need to be reamed and pressed in with an hydraulic press.
This is the video of the top one I recently lowered:
Wired1 wrote:The cheapest way to lower the front on either a ball joint or link/king pin front is to cut the beam and turn it. If you can weld it will cost you only time
That was the done thing 20 years ago but there's no excuse for the cut and turn these days.
Swayaways are cheap as dirt, require the same amount of work and are atleast adjustable once it's all said and done.
Oh yeah welcome to here 😉
Wired1 ·
Thanks, yes I agree - beam adjusters are cheap and not much harder to fit than a cut and turn but I was offering the cheapest way to do it. If money is no object then I would reccommend dropped spindles with beam adjusters and a 2" narrowed beam to compensate for the dropped spindle push out. I'm building a '63 beetle at the moment that has this setup and it is the best way to go as it gives you a good drop but doesn't bugger up the ride quality.
Dean1974 ·
Paul,
Thanks,
Bryce
Hi Paul with front tyre size did that alter speed limit also did you fit adjusters or did you go for shorter shockers??? The reason i am asking i have dropped 2.5 inches and there is no suspension movement very few mm not sure what to do but i will check my front tyre size and i think they are same as rear size....Thanks Dean
Paulc1964au ·
Still have shocks, in the end though i had the guys at RAW install a 2 inch narrowed beam and no more rubbing. As far as i can tell it didnt alter the speed and the circumference hasnt changed from the original tyres
donn ·
So after you change the height of the front do you need to realign the front geometry? I'm thinking of lifting the front of the wench.
5starz ·
Do you have too have a narrowered beam to install drop spindals and adjusters. Or can you just put narrower tyres.
Thanks in advance.
Paulc1964au ·
If I had thinner front tyres I probably wouldnt have needed the 2 inch narrowed beam however there is only so low you can go without narrowing the beam
5starz ·
Oh ok cool. i got the adjusters but want it just a bit lower so thinking thinner tyres and drop spindals. thanks for the reply.
