Aussieveedubbers 路 Tech Talk
Brake pedal return spring
https://forums.aussieveedubbers.com/threads/85684/brake-pedal-return-spring
homer 路
Where does the brake pedal return spring locate into at the floor end on a 74 beetle?Thannks in advance for your help.
STIDUB 路
there should be a little groove for the hook end to sit in on the pushrod pivot point, then the rest goes around the pedal tube/rod then the straight section just sits on the floor i believe, thanks for reminding me though, i need a new one, or 2 馃憤
-i assume yours works the same way as mine anyway, hope that makes sense, cant show you since my pedals arent stock anymore sorry
STIDUB 路
http://www.pedalwerks.com/images/albums/NewAlbum_b6690/68rhdfront.jpg see that, & think of the way the pedal moves & the spring coils/unwinds 馃檪
