I'm about to fit up my Subby 2.5lt engine in my 58 split and getting everything together.
Not sure if anyone has anything about, I have the motor/adaptor plate but chasing the rest of the gear, radiator, thermos, cover etc etc.
My number is 0412 848 579 or reply.
seagull ·
what cover ?
and what is ect ect ?
donn ·
i know what a thermos is, but mines got no lid. 🙁
Hutcho ·
E-bay mate.
STIDUB ·
All Things Subaroo
Shed 10
34 Paisley Drv
Lawnton 4501
ask jason what he's got should be able to help you out 👍
ive got all my stuff for fair prices too
seagull ·
yay for skippy ( ! )
modulus ·
I've got a thermos I could spare.
hth
zeuspig ·
Thanks fellas,
Seagull, I'm not sure what ect ect is but what I meant by etc was the rest of the gear that I would need to complete this conversion.
I have never gone down this path before but I rang customveedub and they have a cover or scoop that goes over the radiator to scoop the air in underneath. that sits between the chasis rails and also the crossmember
Apparently I need to get my loom modified as well as the sump.
They just seemed very pricey for what I would be getting so was seeing if there was other places or if anyone had something.
Otherwise I guess I will hunt the wreckers and make the things up ourselves .....
we did it on the cheap, no fancey sumps etc.
did our wires at home on the shed floor.🤪
ian.mezz ·
got the water pipes made up at the exhaust place, out of exhaust pipe.and
a small radiator made to fit.
fuel pipes from a brake shop.
fuel pump Holden camira / vl commodore
old 20L plastic drum cut up to make air scoops
psimitar ·
Sump can be easily modded your self if you have a grinder and welder.
wiring loom stripping just requires a Haynes manual or some other way to get the wiring diagram plus a little help from on here as to the none engine sensors required to make the ECU work.
