For sale - 091 Gearbox, Subaru adapter and Cranky Kit
https://forums.aussieveedubbers.com/threads/85863/for-sale-091-gearbox-subaru-adapter-and-cranky-kit
Lovebuggy ·
Due to a change in direction with my buggy, I have the following items for sale.
091 gear box - fully rebuilt by Dave Butler so this is as good as brand new if not better - never been used. Stock Ratios - $2200 ONO
CVD Subaru Adapter with balanced clutch and fly wheel - unused. If you thought about doing the conversion for pure power and reliability - then grab this - $1100
Cranky Kit with Subaru Starter Motor to suit 091gearbox. If your 2L starter is getting tired, you can't go past these hi-torque factory subaru starters - $300
Or grab the lot $3300.
Also available 29mm IRS tortion bars - $350.
PM or call if interested.
Located:- Beenleigh, QLD
Ben 0407 172 595.
Lovebuggy ·
Bump - Pictures added
aintgotitmusthaveit ·
Will this starter fit a STD bug gearbox?
seagull ·
aintgotitmusthaveit wrote:Will this starter fit a STD bug gearbox?
This will fit a 5 speed subaru box , but you dont need the adapter plate.
Your just looking for the starter motor on its own.
Lovebuggy ·
No this kit was for the 091 box. Cranky kit do a bug kit - http://www.crankykits.com.au/
Also the pinion on the Starter Motor is changed to suit a 228mm kombi fly wheel.
Lovebuggy ·
Bump - CVD adapter and flywheel pictures added.
Lovebuggy ·
bump
