Gear Shift like poridge
https://forums.aussieveedubbers.com/threads/85887/gear-shift-like-poridge
Kappage ·
Ive been told to tighten it up i can replace the bushes on the gear shift linkages and jsut wondering how to do it and how much its going to cost? at the moment your lucky to find any gears.
costs about $15.00 in parts and a couple of hours if you are a learner
read here
http://forums.aussieveedubbers.com/viewtopic.php?tid=68078
http://www.vw-resource.com/shifter_bushing.html
http://www.vw-resource.com/shift_coupler.html
It will be the read coupler - but do the bush at the front while you are at it
Kappage wrote:Ive been told to tighten it up i can replace the bushes on the gear shift linkages and jsut wondering how to do it and how much its going to cost? at the moment your lucky to find any gears.
WOW THAT IS BAD....
check under the rear seat... under the oval plate...
to see if the linkage is worn/broken etc...
its not a costly project if You can do it yourself....
probably not too expensive having a VW shop do it..
the small cheap nylon bush inside the tunnel is just a fiddly job
so, its not going to cost You much money....
