From the Gregorys:
Depending on the amount of permissible tolerance discrepancy between gudgeon pin and bearing, the pun may be found to be a light finger-push fit in the piston without any heating of the piston. The condition is quite normal, even when the gudgeion pin should happen to slide out of the piston under its own weight. There is no reason whatsoever to replace the pin, piston or both in these conditions.
Oversize gudgeon pins (marked green) are available for cases where the bearing limits are exceeded. The practice of heating the piston is permissible in all cases where no light finger-push fit of the pin is obtained with the piston cold.
The clearance between the gudgeon pin and connecting rod bush is .0001" to .0006". If the clearance is near the wear limit of .0016", renew the pin and the connecting rod bush. No oversize gudgeon pin should be fitted in this case.
The correct clearance will be indicated by a light finger-push fit with the pin oiled after the piston has been heated to 176 (degrees) F.
Ben, please tell me which part of this information is incorrect or inadequate. Also, where does it tell me how to get to Nambucca?
