sold - thanks
https://forums.aussieveedubbers.com/threads/85965/sold-thanks
krisko ·
kombi 5 rib gearbox - $300
chris 0431 231586
Byron Bay 2481
Ollie ·
Working or kaput?
krisko ·
pulled from wrecked kombi - told to be working fine, i have no use for it 😎
Ollie ·
Any major difficulties in hooking these up to a IRS beetle?
barls ·
apart from major work on the forks to fit it. no no problems
wiseoldub ·
talk to the boys at custom vee dub in QLD. I'm pretty sure they have done this a few times, but it takes a bit of fabrication. what makes you want a kombi box?
Ollie ·
Getting a stroker motor so wanted somerthing a bit stronger 🙂
Figured they would be better than a 1600 box. That or spend some big bucks getting my box rebuilt or a Rancho box.
krisko ·
Still for sale
krisko ·
going to ebay - no takers?
dubdan04 ·
mate might know someone thats interested if you havent already put it on ebay.
jamsha71 ·
Hiya,
Has this sold yet?
bajachris88 ·
OMClarke wrote:Getting a stroker motor so wanted somerthing a bit stronger 🙂
If its an irs bug, you can buy an adapter kit. Complete bolt on solution. Kit would come with mounts to adapt the kombi transmission (both front and rear), often a strap for the centre of the transmission and a shifter coupler adapter.
All is left is axles, where you need kombi inners and bug outters.
These kits are common, custom vee dub have em, sharp built have em, even empi has a solid mount mass produced adapter kit.
You would need to change the bell housing of the 1800 box with a 1600 to fit a type 1 motor (unless you go type 4).
