rough running
https://forums.aussieveedubbers.com/threads/85993/rough-running
donn ·
My motor is giving me trouble with rough running, seems to go just fine but (mostly) at low speeds when accelerating it dies then pops and farts for a bit then off it goes, have had the two jets cleared, (the two under the choke, don't know what their called ) which improved it a little but the main problem remains, any clues from the readers out there?
jjwebb123 ·
I had the same problem mate.Found out was my manifold sucking in air.
So replaced the gaskets on the heads,as well as purchased a new carbie.
And all is well.👍
Hope that helps,any question's dont hesitate to pm me.
Good Luck😁
grumble ·
Don is the accelerator pump working? Lift the air filter,hold the choke open and open the throttle slowly,you should see a small jet of fuel in the venturi.Or back to german george.
donn ·
Thanks fellas, have checked as suggested so it's back to German George, though their not German and their names not George. ❓ 😂
johny rotten ·
pay peanuts 👍
get Monkeys 😂😂😂😂😂
donn ·
not peanuts and the only vehicles these two blokes work on are VW been in business at the same address all their working life and their father before them.
johny rotten ·
I have been to that shop
I will say is that Mrs N is an incredible Lady
donn ·
Yeah, looks like they have it sorted, at least 98.67 %. Mrs Nymeyer is a sticker, certainly keeps those boys of hers in line. 😂
