prefferably in a beetle, and with irs, and possibly some form of kafer brace.
im playing with mine and im looking at it thinking... this wwould be a whole lot easier if i rotated the turbo approx 90deg anti clockwise to point the exhaust out to the left rear wheel & have the intake pipe running over the top of the bellhousing...
obviously it would have to come up more, change the oil/water hoses a little and such but it makes getting an exhaust to fit alot easier since it avoids the kafer brace, axle, irs arm etc
also if you have something other than factory stuff from the heads to the turbo id love to see it 馃檪
-bonus of the rotated turbo, makes for a smaller less bendy intake
downside is none of this idea is cheap 馃お
boof2332 路
Other downside is heat... Mine is actually back, down and slightly to the outside....my intake runs under the intercooler and sits on driverside next to gearbox. The exhaust and its heat are all as far away as possible from any thing related to air intake temps.
Matt
hellbugged 路
jvls set up was similar to what your saying dave...ive got his dump and up pipes here doing nothing
STIDUB 路
^^^ could you send me pics of them fitted, not alot of room to play with in here, even better if you were coming up for warwick 馃榾
1303Steve 路
I saved these photos of Pauls exhaust.
1303Steve 路
one more,
I'm thinking about running my pipe under the diff then down down the right side of the motor and have the muffler across the back of the motor.
1303Steve 路
This is how I ran the exhaust under the diff on my old yellow bug
ian.mezz 路
leave the turbo factory mount and just fit a different brace bar set up, and it makes it easier to work on.
Jak Rizzo 路
heres an awesome example for u Dave,
of what not to do.馃檯
Jak
STIDUB 路
im thinking something like pauls could work, but with a Z section coming out from the turbo to kick up around the kafer brace then around/under everything, its going to be fun making this quiet-ish, if only my aim was loud, that easy, 120deg bend out from the turbo to a straight pipe out the top of the guard above/behind the wheel 馃槀 ...add in a super rich tune... fireworks 馃槀
