Bus Front disks on link pin front end
https://forums.aussieveedubbers.com/threads/86156/bus-front-disks-on-link-pin-front-end
Peter O ·
G'day Its many years since I last built a buggy and I have forgotten much of the lingo that surrounds VW parts and people.
Is there a kit available to fit 1970 combi front disks to a link pin front beam.
I do not want to have wide 5 rims and drums on the front and the small 5 stud rims on the rear ( bus gear box and swing arms)
vwo60 ·
Hi, you moght be better of with a beetle disc brake conversion kit with blank rotors so you can have them drilled for the kombi stud pattern, they would be a lot lighter and that would keep the unsprung weight down
Peter O ·
vwo60 wrote:Hi, you moght be better of with a beetle disc brake conversion kit with blank rotors so you can have them drilled for the kombi stud pattern, they would be a lot lighter and that would keep the unsprung weight down
That sounds interesting. who does this conversion kit in Au or do I import from US?
By the way thanks for the quick response
vwo60 ·
Hi, I bring all my parts in from the states and i will give you a example of the cost difference, a CB performance rear disc brake kit to suit my car, $249US plus shipping, from a famous shop here, $900AUS plus GST=$990AUS, you will have to allow for freight and the aussie dollar is getting very good at the moment, get a price here before you order from the states so you can compare the finnal price, if you get it from the states get it sent USPS.
Peter O ·
vwo60 wrote:Hi, I bring all my parts in from the states and i will give you a example of the cost difference, a CB performance rear disc brake kit to suit my car, $249US plus shipping, from a famous shop here, $900AUS plus GST=$990AUS, you will have to allow for freight and the aussie dollar is getting very good at the moment, get a price here before you order from the states so you can compare the finnal price, if you get it from the states get it sent USPS.
I took your advise, I have been looking at a few US sites and the prices are better than I used to pay 25 years ago. I find the info on some like Moore parts for instance a little lacking on detail. Do you have a site that you would recommend, Pacific customs seems to be good price wise.
Thanks for the help
pod ·
why not try volks conversions and keep your dollars in oz
http://www.volksconversions.com.au/
vwo60 ·
the following shop in the US will send USPS and have a good range of gear
http://www.vwparts.net/
Peter O ·
Thanks guys
Is the 5 X 112 wheel stud pattern common to anything other than the VW Bus
vwo60 ·
Mercedes benz is the same as a kombi, you can buy blank rotors and drill them to suit your application.
Peter O ·
vwo60 wrote:Mercedes benz is the same as a kombi, you can buy blank rotors and drill them to suit your application.
Yep thats the plan now but I would like some bigger rims for the rear.
Price on the discs was less than half the AU price landed here so I will be importing them from the US.
vwo60 ·
I don't like being ripped off, hence i spend very little in Australia
