Running on 2 - Help!
https://forums.aussieveedubbers.com/threads/86172/running-on-2-help
chickenfillet ·
Hello Dubbers,
I picked up my 67 yesterday that has been away having shiney new paint applied and now it is only running on 2 cylinders, the right pair are not doing a thing. It was running fine 6-7 weeks ago.
I have pulled the plugs and they are sotty but there was no change after I cleaned them up, I've added fresh fuel etc but it still runs like a dog.
Any ideas? At least it's pretty now....
Kevin
ian.mezz ·
just check the base tune points, timing, make sure choke not stuck.
chickenfillet ·
Hi Ian,
It all seems fine, choke turns off after it warms up and the points are like new.
Is it worth buying some new plugs?
Kevin
greedy53 ·
start the engine and pull of 1 plug lead on the ones not going and see if a spark jumps across the gap,or change dizzy cap
chickenfillet ·
I pulled the lead off the dizzy and it give a big fat spark. Does that mean the plugs are the trouble?
ian.mezz ·
yeah change the plugs as they are cheap or change em to the other 2 and see if those 2 cylinder start missing.😊
chickenfillet ·
New plugs = 4 x explosions!
Thanks for the help guys.
Kevin
