ENGINE OIL SQUIRTER ??
https://forums.aussieveedubbers.com/threads/86186/engine-oil-squirter
dubai ·
I think oil squirts from the front pulley when the engine is running any suggestions.
Thanks guys
ian.mezz ·
check that the engine breather isn't blocked and maybe change the oil if its be in there to long.
dubai wrote:I think oil squirts from the front pulley when the engine is running any suggestions.
Thanks guys
this means Your engine cannot breathe....
so its breathing out past the pulley...
happened to Me early in the year... had the breather blocked off
I'll show You a photo..
SORRY about My engine not being stock...
the rubber hose comes out under the oil filler and goes down thru the tinware under the car, where oil drips usually...
some of the oil will get sucked up into the air cleaner...too...
dubai ·
Guys makes sence I have removed the oil filter and replaced it with a airfilter however i have taken the breather hose from the oil input off to a drink bottle that might be blocked I will check it out in the morning. again thanks for the replys and details its appreciated.
dubai wrote:Guys makes sence I have removed the oil filter and replaced it with a airfilter however i have taken the breather hose from the oil input off to a drink bottle that might be blocked I will check it out in the morning. again thanks for the replys and details its appreciated.
yes
the hose just goes thru the hole in the tinware under the car...
and the oil will drip out...
NOT as much as is coming out now... lol
just the odd drip...
ian.mezz ·
if your car flooding???
Your oil will be full of petrol, smell your dip stick.
change oil
He has blocked the breather hose....
oil comes out where ever it can...
from around the pulley...
I blocked mine a while back when I changed the oil so the oil doesn't pool under the engine...
and it came out the pulley and dipstick hole... lol
jsheppard64 ·
68AutoBug wrote:I'll show You a photo..
at least it's color coded lol
