40HP Crank in 1300-1600 case
https://forums.aussieveedubbers.com/threads/86211/40hp-crank-in-1300-1600-case
sander288 ·
I currently have a 1300 motor (69x77) might need to change to 1200 for historic racing (64x77), just wanted to know what was involed in the swap of cranks.
I'm on the look for a 40HP crank at the moment, and I wanted to know what was involved in putting the new crank in.
Will the rods needs to be changed?
Pistons?
Will the Comp ratio be affected?
Can I use after market barrels and pistons that are for 1600 based motors with this crank? (87-94mm bore)
It would be interesting to find out,
Shaun
1500S ·
I would think you'd have to machine the base of the 1300 cylinders shorter by 2.5mm otherwise CR will be mighty low. Rods and pistons should still fit with the 2.5mm shorter cyls.
DH
dangerous ·
rods use the same bearings,
but the rod is wider at the big end and uses a smaller gudgeon pin.(20mm instead or your 22mm).
the rods use a bolt only, as opposed to the 1300's bolt and nut.
easiest to use the the 1300 case and cylinders(shortened).
i think their length may be shorter too(??)
1200 stuff should be thoroughly checked for size and crack tested!
