Sudden Lack of Power
https://forums.aussieveedubbers.com/threads/86282/sudden-lack-of-power
Blue65 ·
Hi. I went overseas for 3 months - came back, changed the oil in my VW Beetle, started it, it started on the first turn of the key! And I drove it 30km.
But nearing the end of the journey - it started behaving a bit funny. On 2nd gear, the car had a sudden loss of power.
I was pressing the accelerator and then it seemed the engine power just fell through.
I was in a bit of a panic but I just kept on going.
Later. I noticed that I probably did not add enough oil into the engine and put in another 1 litre of oil.
It drove home no problem. But I'm wondering whether it could be serious.
The Beetle is like a 2nd car to me. And since I work from home, I don't need to drive it around a lot.
sander288 ·
How much oil total did you put in the engine? 2.5 litres is what a beetle takes.
It may be ignition related though, points? rotor?
Blue65 ·
sander288 wrote:How much oil total did you put in the engine? 2.5 litres is what a beetle takes.
I put in altogether 3 litres of oil and the dip stick still just shows the oil at half way mark.
My engine is a bit different. Its a 1641cc engine with a specially modified oil filter. basically the conventional oil filter fitted to the side of the engine - it was done by Volkshome.
pod ·
did you put fresh fuel in? as the shelf life of fuel isnt as good as it used to be
greedy53 ·
yer about a month before it turns into crap best to put the fuel saver i have in the mower camper anything that is standing for over a month i learnt the hard way
