chris7 ·
Got a 72 fasty..can pop rear windows be retro fiitted are the mount in the frame? what would be involved to make it work any idea;s info welcome!!!
https://forums.aussieveedubbers.com/threads/86302/type-3-fasty-rear-windows
chris7 ·
1500S ·
chris7 ·
1500S ·
There are no hinges in the Fasty. The front section of the glass/rubber, about 300mm from memory, is held firm by 4? about m3 screws. The glass flexes out from this point. The bodies of all would most likely have the holes for these screws. Most likely you would need to have a plate fitted for the latch mount in the c pillar. Don't know if they are self tappers or M4 as per Notch for the latch attachment.chris7 wrote:Thanks guys..i have the model with sealed windows...so iguess i would have to source new glass with the holes..latch and hinges and replace the window rubber for the type thats opens...just wondered if the factory body of the car has the hole for the hinge and latch because i havent removed the liner yet to check.
chris7 ·
empi ·
