Aussieveedubbers 路 Tech Mods and Frequently asked Questions
Old dogs and turbo tricks
https://forums.aussieveedubbers.com/threads/86376/old-dogs-and-turbo-tricks
snowman9 路
Hi Everyone,
So, it's been three months since I converted my 50,000 km old, hand-built, NA type 1 AS41, German fuel injected cased engine, running stock crank & rods
into a blow through turbo set-up.
The mettle runs @ 7.8/1 static comp., blowing through two
modified (but not that much), 36 DRLA Dellortos.
Modified 050 heads with stock valves, running heavy single springs.
Stock crank n rods actuating a Brazilian AP3 cam.
Turbo is a Garrett GT-17, sourced from a 2002, 95 Saab
with a welded exhaust housing, permitting a synapse style, external wastegate.
Boost is presently @8psi.
I have not been too nice to it of late, and have received zero terminal warning --@8psi-- of immanent hand grenade.
I am happy to post this build and the *methodology* employed -- with pics -- if there is any interest.
Cheers.
pete wood 路
love to see how you put it all together. throw it up here... with pics of course.馃憤
snowman9 路
Thanks for the interest Pete. Shall chuck it up as soon as time permits.
Camo 路
Yes, we are always interested in modifications and especially turbos. I bought a pair of 40mm Dellortos about 2 years ago at a good price just in case I went blow through setup one day 馃お
Look forward to the photos and seeing your setup.
Kev
Newt 路
Snowman,
What is the AP3 cam like?
I am pondering runing one with 1.4 lifters.... (initially N/A then maybe later a lower).
Newt
1303Steve 路
AP3 cam specs
Newt 路
Scuise my ignorance, but what is meant by valve lash? .013 - .015". Is this refering to clearance?
Ta
Newt
1303Steve 路
Newt wrote:Scuise my ignorance, but what is meant by valve lash? .013 - .015". Is this refering to clearance?
Ta
Newt
Thats correct, there are plenty of good turbo grinds around these days, read this http://www.shoptalkforums.com/viewtopic.php?f=34&t=129663
Newt 路
Why would they have such a large clearance?
Newt
