Ok.. I have a type 3. The upper shock bolt hole/thread on one side has a broken bolt. It is not coming out no matter what I try. If i were to drill the old bolt out, get a long bolt then what I was going to use (and not use the thread inside the shock mount) and use a high tensile bolt, washer and nyloc nut on the end... can I do this?
Basically I want to not both into the shock mount and instead bolt through and use a nut at the other end.. thoughts?
jigga ·
