6 volt wipers
https://forums.aussieveedubbers.com/threads/86522/6-volt-wipers
1641 bug ·
can you use 6 volt wipers when converted to 12 volt electrics without burning them out
HappyDaze ·
You can fit a resistor to reduce the voltage.
vlad01 ·
probably for a little while. lol would go as fast as modern car wipers do.
Til it burns out.😀
1916baja ·
I think they just go really fast.
1641 bug wrote:can you use 6 volt wipers when converted to 12 volt electrics without burning them out
You probably would burn them out after a while...
You can buy resistors made for the wiper motors.
or just use the white resistors they use on old car coils
[old fords etc] heaps at the wreckers..
actually You can use two of those.....
one for fast... two in series for slower speed...
or You can use a 1968 beetle two speed 12v wipers..
with proper blades... 1968 ONLY...
Theres an old bloke around here that used to convert 6 volt bugs back in the day using the old 2nd alternator hanging off the original 6 volt gen 😂
He used to use a pair of coil ballast resistors in series on the wiper motor to slow them back down.
running on 12volts they are lucky to touch the glass
better off adapting a later 12 volt 2 speed motor
Lee, all 1500 bugs 68 to early 71 had the same wiper motor, oh and those stupid arms that had grubscrews that slip
Grey 57 ·
you can buy a conversion kit that changes your wiper motor to new 12v armature. $$$ strong so pricings good.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D955%2D811%2DB
oldtub356 ·
Connect a 5Ω 50W Resistor in series with the viper motor - 4Ω, if you want a bit extra oomph.
The 50 Watt Resistors have a HeatSink with x2 mounting screw holes - best to scratch a bit of paint off the adjacent bodywork and screw the resistor over that area. You should use heatsink compound between - but it is a health hazard - a smear of Vaso will stop rust from developing on the scratched area.
If WES Components (Ashfield - Sydney) don't have them, they will tell you where you can get them.
___
(o_!_/o)
___[]___[]___
