Which Case?
https://forums.aussieveedubbers.com/threads/86526/which-case
fast68 ·
Hi All looking at case options for my new turbo motor.
3 really..
CB Alloy case
Autocraft case
Scat case
Engine is 2165
Scat Flanged billet T4 mains
scat rods
CP pistons
Centary cylinders
Comp eliminators 48x40
Web cam 86b 114 L.C
Pauter 1.3 roller rockers
Autronic ECU
Masterpower T-56 turbo
Air to water intercooler
Premium E85 Fuel
Any feed back from your experences would be apprecated.
Nicholai
stoker ·
good luck trying to get an autocraft case ,they dont make more than 20/ year and are as dear as poison. $3.000.00 each Order one
now for 2013@good luck
Is it for the street or race track, long or short course......?
Turbo yeah...but how much boost/power are you chasing?
That said, if street car or even some street, I'd go CB or Scat AL., Scat 3 pce if race only and unlimited budget.
fast68 ·
Thanks for your reply, Street car going in to a 57 oval.Aim is for between 300 to 400 at the wheels.will be drag raced but driven to and from the strip.
hypo-vw ·
we just used a CB aluminum high-top case for Bens supercharged 2442 type-1 engine and we were very impressed with the quality of the case .
They also come clearanced for stroker and machined for big-bore kit . The one that we chose also had a 9mm extra thick deck which is more suitable for some stoker engines .
The only machining required was for the seal for the flanged crank that we used in Bens engine and you can buy suitable main bearings to fit a type-4 centre main crank into the case without machining.
fast68 ·
thanks for the info
Where are u located
will you be building the engine your self ??
perhaps you should talk with the guys at a shop to gain better understanding of whats involved in building a 3 - 400 hp engine both materials and budget
do u have unlimited ???
fast68 ·
I'm in New Zealand, not really may people in this country building engines like this. have most of the parts for it bar the case and a few small bits. My mate DRGouk race engines will be putting it together for me.my last engine was a 2276 IDA engine so this is a big leap!
The Alumnium cases are made by Auto linea, and you will find they are "rebadged" for CB, empi etc.....they certainly are a great foundation for a street motor.
'will find they are "rebadged" for CB, empi etc.....'
They actually start life for the required manufacturer before they are poured into the mould. Autolinea is the foundry and the case is often branded with the name cast into the case at the sump, with there being variations between brands with alloy finish, style of machining, both in the basic shape and quality of the important bearing journals, even clearancing differs brand to brand.
Scat and CB are the best IMO after working with most different brands at one time or another, they seem better finished and have the raised deck available in +5,7 and 9mm iirc.
vlad01 ·
What brand or what is century cylinders?
I tried googleing it but could not fine anything about it. I noticed a few people mentioning them.
fast68 ·
vlad01 wrote:What brand or what is century cylinders?
Sold buy Jaycee, or by other firms to are longer then standard cylinders and meant to be stronger for turbo appilicatons.
matberry wrote:'will find they are "rebadged" for CB, empi etc.....'
Yeah what I meant by 'rebadge' is they all come from the same factory !!!
You will find that each batch seems to evolve, so whoever sells the most cases from a retail point of view tends to have the 'fresher stock'.............I have 3 motors built with these cases and they are ALL different in some way.......the good news is as they make more the quality seems to become better 😎
Century seems to be ok quality in some products, I know there is some of thier stuff I have sent back to the supplier as poor quality.
I'm not convinced P/B kits are better than Mahle though.
Are you sure the stock kits are longer than other manufacturers? I have some to check if I get to it.
As for the origins of thier products, maybe someone else knows.
vlad01 ·
So what would be the best make of cylinders for turbo application?
I am looking at 92 thick walled 94 register. I think length is not an issue as I will be using CB al case and my stroke will be 82.
Turbo54 ·
Fast 68, I am building a very similar motor to you and when researching a brand new case I looked at everything and spoke to a lot people. I was in good contact with Muffler Mike who tested out lots of cases. I went back to the tried and tested Mag case after looking at all the facts. I dont know about now but the first alloy cases became riddled with spider web cracks after abuse of a season of racing. MM tested multiple alloys cases and they all turned up the same. They might be different now, who knows.
My 2 Cents.
T54
BTW my specs are
CB 78 Crank
Street Elims 44x37.5
Pauter 1.25 rockers
Mahle 94's p&B
Scat h beams
Garrett 2871R
Custom water to air intercoolers
Custom exhaust manifold
Haltech E6X
Keep us up to date with the build. Very Interested.
T54
vlad01 ·
Its very likely that those crack were caused by the crank pounding the crap out of the case.
Balance is key. Where about were the cracks?
Turbo54 ·
All over. They were like a web. They showed up with scanning of the case after a season of racing. Knowing MM engine building skills I am not sure it would of been that. Maybe but not convinced. Like I said. These were early days in the alloy cases and may have been addressed.
T54
vlad01 ·
Actually I have heard this before with the first batches of the Al cases.
Cracks all over would be defective manufacturing. Cracks around No 3 cylinder are caused by imbalance or out of center balanced cranks.(pounding the case)
Cracks or line bore damage near No 3 and 4 bearings normally caused by harmonic vibrations which is characteristic of using light weight pulleys.
2443TT ·
WBX or the TF1 are two options you might want to look at as well.
The company that makes the TF1 was just about to do a production run about a year ago so they might be available now.
dragvw2180 ·
I am a big fan of the CB case, quality is very good and it is what I have in my turbo engine. I tore it down to change the cam for a new combo and the bearing surfaces looked like brand new, I was very impressed.
Mike
Thanks Mike, I have a few builds where I have gone this way, it's just too early to tell, so a little reassurance is always nice.
