wanted: VIC: 12v wiper motor
https://forums.aussieveedubbers.com/threads/86545/wanted-vic-12v-wiper-motor
donn ·
location location location ?
donn ·
I have one in Newcastle but you are sure to get one closer.
gizzo ·
would you c.o.d it through australia post. if so how much for it. thanks campbell
gizzo wrote:wanted , 12 volt two speed wiper motor 68 or later to replace 6 volt single speed motor in 1960 beetle. or any info on fitting one from a different car ,
the 1968 wiper assembly has the same size wiper shafts as the early cars but proper blades and two speed...
wiper assemblies from 1969> will need larger holes in the body to fit the larger shaft..
gizzo ·
thanks lee i only need the motor ,im running series 1 landrover spring loaded wiper assembleys,with small modification. which you can buy from your rover dealer. il put a picture in the tech mods section
Calcool ·
Hi,
I have an early 68 Beetle Wiper Motor with the splined drive shaft that is the same as the 6 Volt Wiper Motor so it is a stright swap onto the 6Volt wiper bracketry.
Just fit a 2 speed switch
$50 plus postage I am in Brisbane.
David 0434 58 22 64
gizzo ·
sold .... il ring ya
PASHN8 ·
Hi guys, i'm another one in need of a 68 12v wiper motor for my '59. Any help?
PASHN8 ·
Anymore 6v or 12v early wiper motors?
Will take a 6v motor if it is a SWF made motor and not a Bosch unit?
bushed ·
i hve a Golf mk2 one if it helps
u said 12 volt NOT what car
have arms etc compl
gizzo wrote:thanks lee
i only need the motor ,im running series 1 land rover spring loaded wiper assemblies,with small modification. which you can buy from your rover dealer. il put a picture in the tech mods section
Yes,
I remember the Land Rover stainless steel wiper blades...
Lucas??
they would look better than the painted ones....
but they are English and it wouldn't be right... lol
I have a new Lucas fuse box but I wouldn't use it.... lol
gizzo ·
lucas, prince of darkness??????
PASHN8 ·
Ok, secured a '67 12V 2-speed wiper motor!
Now just need a matching 12v 2-speed small wiper cowl shaft switch? Anyone assist?
