I have several good race engines here that I will be slowly building them to sell off as I am up-grading to larger capacity engines . This one is has the following components :
* 4 piece Autocraft Aluminium case , 94mm bore with std type 4 mains , cut for flanged crank
* Scat forged 86mm flanged crank , std type 4 mains and std porsche rod jnl
* Carrillo 5.7 H beam rods with new bolts
* Autocraft 9526 steel nose cam with Magnum straight cut gears { or cam of your choice }
* Wiseco 94mm Forged pistons , HPC ceramic tops and teflon skirts , with new total seal rings and teflon buttons
* Century long cylinders to be cut to length
* Autocraft 910 heads , 48.5 x 37.5 titamium valves , K 800 springs , HPC ceramic chambers and ex. ports , 37cc , flow 237cfm @ 25" @ 600 lift
* Autocraft 1.25 pro-series rockers
* Autocraft dual tapered pushrods and spring loaded tubes
* Autocraft 3 stage dry sump pump
* Scat flanged flywheel with 180mm dual disc set-up
* Match ported intake manifolds with 51mm IDA's
This engine can be sold un-assembled or I will assemble to your requirements . All parts have been magnafluxed and passed all good . I also have a complete turbo system including a freshened Garret T72 turbo , complete 2'' HPC coated exhaust , 2 x turbosmart wastegates , fabricated HPC coated intake manifold with a chassis shop blow off valve and complete methanol fuel injection system . This engine has produced 245 HP on carbs and 497 HP with 22psi boost . This is a full race deal only and will require regular maintainance and is located in Wollongong NSW and is priced @ $ 10,500 with carbs or $ 14,000 with turbo deal , ROD , 02-42729920 .
RodPenrose 路
