Hi Guys.
Just got a new alternator to replace my dead old generator.Wiring is a bit different,thought i might open this thread just in case i have any questions or need help.
Would be great for some support.
Thanks in Advance.
~Jas~
jjwebb123 ·
Is an ALT light,just the gen light already in my dash?❓
jjwebb123 ·
help.
zocstar ·
Yes.
jjwebb123 ·
ah ok.The alternator that i got has a built in regulator ,i have heard this is quite common and
people somehow splice a certain wire to another wire and hey presto.by passing the reg under
the seat.
Would anyone be able to clarify that for me.
jjwebb123 wrote:ah ok.The alternator that i got has a built in regulator ,i have heard this is quite common and
the seat.
Yes Jason
I have sent You a PM tonight...
donn ·
You would be better off posting in "Tech Talk"
jjwebb123 ·
didnt get any pm lee.🙁
57 oval ·
Jase
you have probally picked up on it already but if you go to the topic activity tab at the top of the page you will see that some one else is asking the same question, there are a couple of good diagrams there mate, should sort your problem out
jjwebb123 ·
yeh i know mate,few of my comments there as well.lol
but i appreciate your help. cheers
sent another pm to you
this one did go thu
jjwebb123 ·
SHe is on the road,everything is connected and i am taking clemy to work tomorrow.thanks everyone for all your help,and putting up with my constant nagging.Check out the pic.
If you have J-pipes you need to plug that right hand heater outlet being right up north, or if you still have heaterboxes refit the heater hoses, even if you dont use the heaters.
its an important but frequently overlooked part of the cooling system
jjwebb123 ·
Joel wrote:If you have J-pipes you need to plug that right hand heater outlet being right up north, or if you still have heaterboxes refit the heater hoses, even if you dont use the heaters.
Hi Joel.
Oh ok, i did not know that.I do have j-pipes,we did that a while back when i had my old coil and it was getting to hot.It stopped when we unblocked that side.But now i have new coil,it should be fine.
Thanks for the heads up.😎
