i have a 57 oval can i change the solid beam gearbox for cv still set up
https://forums.aussieveedubbers.com/threads/86570/i-have-a-57-oval-can-i-change-the-solid-beam-gearbox-for-cv-still-set-up
lownsneaky ·
i have a 57 oval can i change the solid beam gearbox for cv still set up like an irs set up
rose ·
give Vintage Vee Dub they will tell you
ph 0297 891 777
vwsteve ·
if you weld in irs pivot boxes and swap it all over
lownsneaky ·
sweet anymore info
Birdman ·
You will need to buy aftermarket (or cut from an irs beam) brackets and borrow a irs bracket jig from someone.
Then have the brackets PROFESSIONALLY welded to your beam.
Then you need new spring plates, the irs arms, axles, cv's and a new box.
I have a complete beetle irs rear end and 1600L SSP box in marrickville if you are interested.
