yep no mention of it there is pinging its head off running 98 oct and standard comp ive nocked the timing down im over it .......................
matberry 路
What timing and dissy u running?
bugzla 路
dis-x as for the timing its back as far as it goes notch on split of block
Bizarre 路
do you have a 009 just to see if it makes a difference??
bugzla 路
all ive got at the moment is 010 which is more aggressive i used my 009 for the conversion for the dis x
greedy53 路
i had very similar rolem with m ute turned out that 1 carby float was not filling up a simple poke and bend fixed it
bugzla 路
ill give it a go thanks man
bugzla 路
okay done that and increased the main jet still pinging but not as bad but running really rich wound the timing back as much as i can still doing it ive got a degree pulley but no puller to get the old one off its really frustating
cesiumfrog 路
was it running ok before you touched it?
thats always my first question to myself when things turn to shit.
matberry 路
You need to set the timing accurately, even the stock pulley will tell you. An adjustable timing light or a few marks on the pulley and calculate from the original marks to fin total advance is necessary.
bugzla 路
ill change back to the single carb and see what happens
